leehljp
Member Liaison
Here is a question that might bring out some opinions but I would like a discussion on this. I especially would appreciate responses from those that work with metal and metal forming equipment.
What probably causes flaring of tubes the most? Too much pressure or slippage?
In this post (click here) Keith (Russel) asks about flaring the tubes if the live center and drive center are too tight in the mandrel-less set-up.
I am a learner so I am open to opinions and learning the truth. It is my opinion from observations that "slippage" causes more flaring than over tightening the tail stock wheel itself (within reason).
I am aware from experience that differential speeds between two metals will cause deformity quick. It can be done by pressure alone but it is easier with the differential speeds of the brass tube and drive centers, IMO. And this is caused by too little tail stock pressure, or too much sanding, finishing and buffing pressure, again in my thinking.
I will say that once bushings are off, AFTER turning to near size, there should not be enough pressure from sanding and finishing to slow or stop the blank.
Opinions and insights on the most probable cause of tube flaring? (Outside of the assembly process.)
