Tru-Stone Repairs??
Karl_99
Winfield, PA
I was assembling a TruStone tube and it cracked when I was pressing the coupler end in the tube. Is there any way to repair a crack in TruStone? The pieces did not break out.
Thank you
Mr Vic
Falcon, CO
You can drizzle some thin CA into the crack, wrap with wax paper and clamp. May have to re-polish after it cures. The crack will most likely be undetectable. I've used the technique with blow outs from impatient drilling.
Dale Lynch
Hastings,NE
you can hide the cracks in blacks by doing as posted above.The lighter the color the more visible the split will be.
