TRU Stone
7miles
North Pekin, ILL. USA.
I'm going to be turning my first tru stone today is there anything I should know about it...I got it from CSUSA, I also want to know I need to turn them that same way. I have two diff. ones. 239-0110 Royal Flame and 239-0101 Turquoise. And to finish it, is it best to MM to 12000 and polish or buff?
ed4copies
Local Chapter Manager
Racine, WI, USA.
Keep heat down. Possibly use water to cool while drilling.
I've had very MIXED results - blew up 2 that NEVER should have broken. LOTS of room on all sides, drill bit less than half way through, the blank just separated.
NOT my favorite material.
Good luck - I HAVE made a few that worked. Seems every blank has it's own characteristics - not a feature I would recommend.
THIS IS NOT TO Condemn the lot of "Tru-Stone". I have recently purchased from our member RandB??Crafts. I look forward to trying his - he has actually TURNED them, so I expect better results.
FWIW
broitblat
Bellevue, WA, USA.
I've done a few TruStone pens and haven't lost one yet :). For the most part, I don't think they take any special technique, but I suggest you knock off the corners with a sander before turning, keep your tools sharp, and a light touch. I've generally finished the way you've suggested -- MM to 12000 then polish and wax. I think some folks prefer to wet-sand, but I haven't done it that way. You do want to be careful about heat build-up, so use a light touch on sanding, too. I've also tried plastic polish which seems to work OK.
They're a little more work, but the results are worth it.
Good luck!
-Barry
Milpaul
Milwaukee, WI.
I think you will really enjoy turning the tru-stone. I was hesitant at first myself, but have never had a problem, just take it slow. As Ed said each type is a little different but you will love the turquoise. It looks great and compliments any kit. I also use MM. It us up to you if you think a polish is necessary but the MM usually gives a good finish on its own.
wdcav1952
Activities Manager Emeritus
FWIW
Don't feel bad Ed. Once you get a little acrylic experience under you belt you will be able to have some success with Tru-Stone.
ed4copies
Racine, WI, USA.
Yeah, Cav.
I figure another 4 or 5 pens and I'll have 'er licked!!!
The last 2000 really didn't mean much!
randbcrafts
Jacksonville, FL, USA.
Use a sharp drill bit, standard split point works best for me rather than the brad point, but either will work. I always turn mine with a gouge and then finish with a skew. Sand through all the grits and wet sand with MM. Polish with plastic polish. Piece of cake!:)
Chasper
Indiana
I damaged one in the final friction polishing stage; too much pressure and it heated up and bubbled out. Use a light touch in the polishing if you make it that far.
