Trouble with a Rockler kit
DrBills
Atlanta, GA
Has anybody else had troubles with the Cigar Pen Kit #23707?
http://www.rockler.com/product.cfm?page=19563
I have tried to make this pen twice now and have had the middle two ends seeming to be switched, as if the bushings were reversed.
I am pretty good at following instructions, so I am reasonably sure I am setting the mandrel up as written. Thoughts or similar problems?
Thanks,
Bill
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
Cause
The only thing I can think of that would cause that IS getting the middle bushings reversed - most likely by getting the upper and lower blanks recversed.
hilltopper46
East Troy, Wisconsin, USA.
I think everyone who makes any number of cigars sooner or later gets the bushings switched for the barrels.
If it is a really pretty piece of wood or acrylic, all is not lost. You can modify the pen by gluing a piece on the top (shorter) barrel to make up for the clunky standard centerband and turn it down to the lower barrel (smaller) bushing, then turn the lower barrel down to the correct (smaller bushing), then put the pen together without the standard centerband. That's what I did with the acrylic pen shown here.
The other two, I left the centerband out on purpose.
I do turn the flange off the standard centerband and insert it in the upper barrel to help center the transmission - I'm not sure how necessary it is to do that.
DrBills
Atlanta, GA
Thanks for all the feedback gang.
Using JTTHECLOCKMAN's suggestion, I used my digital calipers to ensure size and order. I also videoed what I was doing in case it still came out wrong.
Of course it was just fine. :redface:
Thanks again,
Wild Bill
