Triton tubes
cmccarter
columbia, sc
Can anyone verify that the triton fp uses the following tubes. The Library referances do not include the triton.
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
MarkD
Sayre, PA
If you don't get an answer I can check when I get home tonight. I do know that the tubes are the same as a Jr Gent II with the exception that the lower tube is shorter ( .230" shorter if I remember correctly ).
Silverado
Hello Chester
Those are the Right dimensions. I just opened a kit and measured them.
mark james
IAP Collection, Curator
Medina, Ohio
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
Same as the Atrax, so I think
Cap - 1.9"
Lower - 2.19"
I've been swapping out both recently.
cmccarter
columbia, sc
tnx
thanks all. some how I managed to have a kit that I had removed the tubes from. now to get that bokote cut and glued
ed4copies
Local Chapter Manager
Racine, WI, USA.
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
Cap - 1.9"
Lower - 2.19"
Actually, Mark, the Atrax body is longer than the Triton (with the supplied tubes). Yes, you CAN make the Triton on Atrax (or Junior series) tubes, but you have to change the spring on the rollerball--it needs to be a little longer. If you are making the fountain pen, no modification is needed.
FWIW,
Ed
mark james
Medina, Ohio
cap 12.5mm x 1.9"
lower 10.5 x 1.85"
tia
Cap - 1.9"
Lower - 2.19"
FWIW,
Ed
Thanks for the correction! :redface: (I'll blame my calipers, or my stock system, or my cats...)
