Originally posted by TXTurner
Question - if I'm using the micromesh to 12000, do I still need to use tripoli, or can I get by with White Diamond only?
Mark
OK, you're going backwards! Just for grins, next time stop at mm3000 then buff with tripoli and white diamond and see if you can tell any difference... other than you saved some time![]Originally posted by pipeyeti
I know that some will say that I'm going backwards,but I use the tripoli after the mm and am very happy with my results.
Originally posted by redfishsc
For acrylics, I sand up to 800 grit and buff with Tripoli/white diamond and get a flawless shine every time. Going past 800 or 1000 grit sandpaper (1500/2400 range in MM) is a waste of time.
Originally posted by Blind_Squirrel
I'll go you one better by saying going past 320 or 400 grit is a waste of time. For acrylics, I sand with 320 grit abranet then buff with tripoli, white diamond, and finish off with Renwax. I get a flawless shine every time.
Originally posted by RussFairfield
Everybody has to determine what medium is the best for them, and how fine a grit particle to use. Once we get past 600 grit, the differences between the various abrasive mediums is small and subtle, and which we prefer depends on our technique, the material we are polishing, and what looks the best to us.
Nice thing about turning, sanding, applying CA and polishing is that you can very quickly turn a blank around between centers so you are going the opposite direction.Originally posted by kent4Him
... Novus on the lathe is polishing the same direction as sanding and applying the CA finish.
Exactly what I do. I also leave the barrels on the mandrel while buffing so as not to round the edges. Unless I want a round edge( upper part of the lower barrel on a cigar pen)Originally posted by ed4copies
True, but you would LIKE to go PERPENDICULAR to the radial scratches, if you wish to truly REMOVE them. This is easiest to accomplish on a buffing system. (IMO)
Yes and this is how I also buff my blanks EXCEPT without the mandrels. Mandrels... yuk, patewee![] I just hold my blanks with my hands and get a nice nail polish job while I'm at it! I was simply saying that one doesn't have to always turn the blank in the same direction if they don't want to and I've talked to some who never thought of reversing the blanks.Originally posted by pipeyeti
