When the punches are sitting in the standard rack, each in sequential order, it is easy to just slide the blank over the punch, to size it. If
no fit, step down...
if loose, step up. Quick 'n easy. Nothing to remember except to return the punches to the rack after each use (which will be a great organizational practice in and of itself!).
ADDED TIP:
resent
No extra charge! :tongue
If you have the dedicated pen maker's set, meaning no punch
point on one end, then you will want to ID which end is inserted into the pen for disassembly, and which end gets hit with the hammer, and thus will 'mushroom' out a bit. Lay out ALL the punches on a scrap sheet of cardboard in an orderly fashion, side-by-side. Then lay another piece of cardboard to mask about 90% of the length of the punches. Hit the small revealed end of the punches with a light coat of bright color spray paint. Now you have the "HIT 'EM" :hammer:end and the "PRECISION SIZE" end readily identified. No need to periodically file off the mushroom.
