Tools compatible with Woodchuck pro ?
Eddie1234
Norway
Hello.
I am going back to pen turning, after been away for a while.
I used to use Woodchuck pen pro, but the tool has gone missing, but i still have a load of the inserts, both R2 and R4.
I am trying to get hold of a new woodchuck pro, but woodchucks webpage is flagged as infested, and Berea, who also sells the products, is out of stock.
Do any here now if the inserts that fits the Pen Pro is compatible with any of the other tools that are being sold, like EWT, or PSI Genie ?
Thank you
Vegard
Childress, Texas
As far as I know, the inserts are not compatible with the EWT line. I think I saw a line in the PSI catalog about the Geni being compatible with EWT.
Try R and B Crafts for the Woodchuck Pro.
Eddie1234
Norway
Hey.
Thanks for the advice, i will contact r and b crafts, and see if they deliver to Norway.
Thank you
Vegard
Eddie1234
Norway
Eddie I made my own using 3/8" square stock. I drilled and tapped for the screw then filed down the space for the cutter. Then make your own handle.
That sounds like a good idea, if I only had the tools for doing that...
But thanks for the thougth !
Vegard
