dhallnc
What do you folks find to be an acceptable tolerance between barrel and fitting to achieve smooth fits?
Thanks.
Thanks.
If the fitting is .511, then the barrel must also be .511. This is partially why we do not turn out 100s of pens and we go through caliper batteries like M&Ms. :frown:
I'm just not that good yet.
When you turn your barrel, you turn it under in order to build up with finish. Then you lose some size as you go through the MM.
What are you shooting in first 2 steps?
Thanks!
Thanks!
