randyrls
Because cigar pens and some others have double twist transmissions, I put a drop of CA on threads where the transmission screws into the lower tube to lock the transmission to the lower tube. This also allows you to adjust how far the point extends from the nib. The instructions I include say "to replace the ink cartridge unscrew the writing point (nib) end of the pen".
This trick prevents the user from unscrewing the transmission when twisting the pen in the same direction as the threads.
