"Tiny bubbles in the glue" - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 03-31-2018, 01:46 PM   #1 (permalink)
Woodchipper's Avatar
Photos: 1
Question "Tiny bubbles in the glue"
Don Ho sang about tiny bubbles in the wine. I got tiny bubbles in the glue. I was turning an acrylic piece this morning. It became translucent and the bubbles stuck out like sore thumb. Plus one end cracked so I tossed it. SWMBO and I saw some great pens at our local Woodcraft store a while back. This pen turner mixed acrylic and wood. Need to check my wood and see what would complement the gold and blue swirl acrylic. Your suggestions are most welcome.
BTW, it is a Slimline pen so the blanks are turned down very thin, as you all know. I made a tube insert tool out of a piece of plastic I got at the recycling center. I insert the tube and turn it as I insert it.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 03-31-2018, 03:19 PM   #2 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Are you painting the inside of the blank after you drill it and before you glue the tube in?
This thread discusses the painting of the inside of the blank before gluing the tube in. The focus is on the color of the paint for the inside:
Seeing is believing - Reverse Painting
This thread covers "painting the Tube vs Painting the inside of the blank.
Painting tubes vs blanks
Painting the inside of the drilled out blank on cast blanks prevents the tube or glue bubbles from showing through.
__________________
Hank Lee
Good is the enemy of Best
leehljp is offline   Reply With Quote Top
Old 04-01-2018, 10:02 AM   #3 (permalink)
Photos: 1
Default
Didn't paint either part, blank or tube. Painting the inside of the blank would hide the bubbles. Need to check the links on this. Thanks. What was bad was the chip in the end!
__________________
Advertisement
Old 04-01-2018, 10:23 AM   #4 (permalink)
MRDucks2's Avatar
Photos: 0
Default
Painting the inside of the blanks will help a lot in hiding the “bubbles” but it will not help the chip on the end. The bubbles you see are where the blank and the tube are not adhering to each other. For me, it is a lack of glue on both the blank and the tube. I can get glue on all of the tube and have been getting more in the blank but still lack consistency.
By getting better I mean I can ensure I get a good coat in about the first 1/4 - 1/3 of the blank from each end. That helps prevent chipping out the thinner areas.
__________________
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 04-01-2018, 11:28 AM   #5 (permalink)
magpens's Avatar
Photos: 75
Default
I am not clear on what you are talking about ... pic would help please ... even a mediocre pic.
Does the tube insert tool you made have anything to do with the main issue of bubbles ?
Do you think that using this insert could be one of the possible causes of the bubbles ?
In my experience, incomplete glue coverage in the small space between brass tube and blank material is just a fact of life.
Many manufacturers' instruction sheets tell you to twist the brass tube as you insert it, to "ensure uniform coverage of glue".
But I have found that to be a virtually non-achievable goal. With even partially translucent acrylic materials, painting the hole has been the only way I have found to hide the gluing non-uniformities which are inevitable and unavoidable.
Quote:
Originally Posted by Woodchipper View Post
I got tiny bubbles in the glue. I was turning an acrylic piece this morning. It became translucent and the bubbles stuck out like sore thumb. ..... Your suggestions are most welcome.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 04-03-2018, 11:34 AM   #6 (permalink)
pshrynk's Avatar
Photos: 0
Default
How do you feel Gorilla Glue does at filling in? I've been using it recently and have been pleased with how it sticks better but haven't had any problems with bubbles with any of the blanks I've used. Luck more than skill, I'm sure.
__________________
Hello! My name is Brian and I'm a pen turner...
pshrynk is offline   Reply With Quote Top
Old 04-03-2018, 12:12 PM   #7 (permalink)
Photos: 0
Default
I have moved to using gorilla glue from CA having good results. You have to turn,twist tube when installing to get complete coverage wth any type of glue.
Painting blanks is a good idea also for any non wood material.
Charlie
Dieseldoc is offline   Reply With Quote Top
Old 04-03-2018, 01:28 PM   #8 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
One thing to watch for in using gorilla glue: As it expands, in some cases it has been known to push the tube outward on one end. So, tape the ends into place to prevent this from happening. It only happens on the most expensive or the 1 in 1000 blanks!
__________________
Hank Lee
Old 04-03-2018, 03:29 PM   #9 (permalink)
pshrynk's Avatar
Photos: 0
Default
Quote:
Toothpicks and rubber bands work, too...
__________________
Old 04-03-2018, 03:54 PM   #10 (permalink)
randyrls's Avatar
Photos: 68
Default
John; to avoid cracking on the ends of the pen, use the cut long, drill short, cut off end. This is a blank prep article.
Hope this helps.
__________________
Randy S.
Experience, ah, experience; Experience is what you get when you don't have experience!
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
randyrls is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
bubbles , glue , slimline acrylic , wood
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
