TBC bushings
Band Saw Box
Passed Away Dec 8, 2021
Hampton, VA 23666
My dead and live centers arrived yesterday so I can now try a pen TBC.
I want to start using bushing. Can I use the bushing that I use for the kit I'm using or should I get some TBC bushing and if so were can them. I'm going yo try a pen with out bushing once I can find my caliper. Thank for the help.
Jim Smith
Lakeland, FL
You can use the bushings that come with kits. They won't always match the 60 degree cone on your live/dead centers, but it will work. That said, I have much more confidence TBC with the bushings made for that purpose, not to mention that they are FAR better quality bushings.
Jim Smith
sschering
Eugene, OR
All I can say is mount up the bushings with a tube and see how it spins..
If it runs true go for it.. If not then look at having 60° seats cut in them (know someone with a metal lathe?) or ordering the TBC bushings.
I have only had one set of bushings that didn't run true.
edstreet
No longer confused....
It is all about surface area. Surface area on the contacting points, in this case it's the bushing and the live/dead center. Factory bushings are not the same angle and will not provide the vast surface area that TBC bushings do but they will provide some. However, you can still use factory bushings but know this, there is a limit and once that limit is reached you will have slippage, could be the bushing to live/dead center (more than likely) or bushing to tube and in that case the harder material will win out and the softer material will be eaten away and damaged. Often times you will see chisel cuts stopping the blank from turning and the bushings or the live/dead centers just spinning away and doing nothing, quite the frustration to.
Lenny
Searsport, Maine
John's bushings are great but unfortunately he isn't making them anymore.
Don't let that stop you from trying TBC though with the regular bushings. If you have a collet chuck you can even attempt to drill a 60 degree chamfer in the ends of the bushings to better mate with your centers.
Would love to know if anyone else decides to start making bushings in the future.
toddlajoie
Feeding Hills MA
I'll second the lament that John isn't making bushings anymore. I have several of his sets and several from another source, and I like his MUCH better...
Another thing to consider, I only use TBC bushings for pen kits that I do often (baron/Naigator, Jr Gent series, Cigar, & Wall St II) and I only use them to get close to size. Once I'm round and down to near the bushings, they come out and the blank gets mounted right between centers and I use digital calipers as I turn down to size. It is a bit slower, as you have to stop the lathe to measure, and you have to be VERY careful not to crank down your tailstock any more than necessary, but it allows for a fit to the pen parts that I could never seem to achieve by just turning to the bushings, and I have never had a problem with the SLIGHT flaring of the tubes that happens from having them right on the centers, but again, your mileage will vary with the amount of pressure you put on the tailstock...
The great thing about getting the hang of this is that I can turn ANY kit between centers, I don't need the bushings, they just speed up getting close to size I've never had a problem knocking a square blank round with it between centers with no bushings, and as long as I measure the parts, I know what my final turned measurement needs to be.
glen r
Edmonton, Alberta, Canada T5W 1V8
Lenny, I just ordered 2 sets from John so he is still making bushings. I believe that he is giving a priority to his job and making bushings is something he does in his off hours. His site states that if its not listed he doesn't have it now but will likely in the future. From what I read, if you really want a set of bushings that are out of stock he will make them for you if you prepay for the bushings and shipping.
Dan Masshardt
Mechanicsburg, PA
It's worth emailing john to at least ask if you need something.
His free time is less but I wouldn't be surprised if he gets more active in it again sometime in the future.
If you can use one if the few kits listed though, don't hesitate.
LeeR
Fort Collins, Colorado
I've got a friend with a Haas machining center. I ought to see if he is interested. We have done some collaborative projects together in the past.
I just ordered a dead center for my lathe, and was considering drilling out my conventional bushings to use TBC, but if there is a market, it is worth pursuing making TBC bushings to sell.
Once I know, I'll need to understand priorities for which bushings to offer first.
edstreet
Where is this info obtained from? Like where does it say he is no longer making TBC bushings?
Lenny
Searsport, Maine
John told me he just didn't have time anymore. That doesn't necessarily mean he won't again at some point. I certainly hope that's the case.
Jasper Indiana
Depending on the sizes of bushings you are looking for Constant at Lazerlinez has some. He has Jr's, Sierra, 8mm bullet and 3/8" bullet, Navigator, Baron, Tycoon and of course the sizes for the pens he produces.
Mike
Dan Masshardt
Mechanicsburg, PA
Depending on the sizes of bushings you are looking for Constant at Lazerlinez has some. He has Jr's, Sierra, 8mm bullet and 3/8" bullet, Navigator, Baron, Tycoon and of course the sizes for the pens he produces. Mike
I have some of these and like them as well. They don't have quite as much surface contact area as they are drilled for a mandrel as well, but they work well enough for me and the price is good.
These are the only two sources that I know of. Besides having someone make them for you.
Charlie_W
Sterling, VA USA
Mike
On Lazerlinez site, you will need to click on USA made pen kits. The bushings are all in with the stainless steel kits. Just scroll down to see them.
LeeR
I thought I might at least get a response regarding some particular TBC bushing that is not available anywhere. The two suppliers mentioned apparently have limited availability and selection. Should I assume that there is little need for someone else offering TBC bushings? My tendency would be to make "TBC-only" bushings so that the mandrel hole is eliminated, and thereby maximize contact area with the drive and live centers.
I'll pursue offering bushings if it makes sense.
Thanks for any feedback you could provide.
Dan Masshardt
Mechanicsburg, PA
I thought I might at least get a response regarding some particular TBC bushing that is not available anywhere. The two suppliers mentioned apparently have limited availability and selection. Should I assume that there is little need for someone else offering TBC bushings? My tendency would be to make "TBC-only" bushings so that the mandrel hole is eliminated, and thereby maximize contact area with the drive and live centers. I'll pursue offering bushings if it makes sense. Thanks for any feedback you could provide.
Maybe you should post in the market research forum.
I have most of the sets that I need, but would be interested in others in the future.
Price is certainly a factor as well.
If it's something you'd like to explore, I'd consider a trial run of a couple popular sizes like jr gent 2 or Sierra.
Jim Burr
Banned
Reno, Nv
I was fortunate to get just about every TBC set John had up to late last year. He is trying to work for a living which translates to $ to pay the bills. He's still in the mix, but on hiatus.
LeeR
Thanks for your feedback. I also got a PM suggesting a post in the Market Research Forum, and I'll pursue this. Since I just retired, I do not have that 9-to-5 diversion to get in the way of doing the really important, and fun stuff!
However, my friend with the CNC equipment does still work, so I'll have to see what his schedule looks like. We have done some custom tooling together a few years ago, and this project would be a lot simpler, and probably much easier for him to fit in.
LeeR
I have posted my TBC bushings query in the Market Research forum.
I'll make a list of what bushings are currently available. I am not looking to compete with other vendors -- yet. I would rather fill the holes in the market offerings as a first priority.
Albion, MI, 49224
I just drill them with a 60 degree center. tada!
