You can also adjust the nut/bold that holds it down. Turn the crank so the tail stock is in loose sliding mode, reach underneath and tighten the nut a 1/4 turn and give it a try. If still not holding..do it again until you get nut to where you like it. A larger washer under the nut can also help with more gripping surface, but I never found it to be needed on mine.
