KP
Folks -
I managed to screw up the assembly of a nice olive gentleman's pen. I hadn't used this kit in a few years, so it was essentially like a first time. Anyhow, I put the nib coupler in without that little metal ring, so the end of the wood is exposed. I was doing it in the order given in the instructions, so the end cap is already on the other end.
So, any ideas on a fix? I know folks use the HF punch set for disassembling pens, but I'm not sure I understand how, and in any case I don't have one (although I never am averse to getting a new tool).
The only idea I had was to use a dremel to make the center hole of the ring a bit bigger so it'd slide over the nib coupler threads, and then use a drop of epoxy to hold it in place to prevent it coming back off. However, I can easily see that the dremel might just ruin the ring, as it's going to be hard to hold it and grind it out just a bit.
The pen is to be a gift. A tiny imperfection, although it'd bother me, is likely to never be noticed or cared about by this particular recipient.
All ideas welcome. Now, I'm going to go and kick myself in the rear a few times for screwing up a nice pen at the final step.
Thanks -
Ken
Thanks -
Ken
