crokett
Ok. I made a stylus for my new Kindle Fire but it wasn't working. I discovered if I hold the metal part of the stylus tip while I am using it, it works fine. The store bought one works with me just holding the plastic. If I hold my stylus down on the screen long enough without touching the tip it works. I did not use a kit to make my stylus. I used an extra tip I had, an extra 7mm tube and a clip salvaged from a slimline. My 7mm bit was not long enough for the blank. drilled part way into each end of the acrylic blank glued in a 1" piece of tube and turned between centers. Is that my problem?
