Stone pen blank - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 01-30-2019, 10:27 AM   #1 (permalink)
Photos: 0
Default Stone pen blank
My son gave me a stone pen blank he picked up. Any hints or suggestions before I put this on the lathe. Realize I am going to need carbide tools to work this and probably should knock the corners off on a disc sander prior to starting. Figuring on drilling on lathe so need to find a way to place a block behind the end to prevent blowout. Just looking for helpful hints since it was a birthday gift.
Don
Teacher is offline   Reply With Quote Top
Old 01-30-2019, 11:00 AM   #2 (permalink)
Photos: 1
Default
What kind of stone? How hard is it? Research mohs scale and test the hardness. If the hardness is below 3-4 you can drill and turn on a standard wood lathe. For mohs 5-6 you might be able to turn with carbide cutters is you are slow and careful. For mohs 7-8 and above you will need a lapidary lathe with a water cooled grinder cutter.
Try masonary bits for drilling. Drill with a small bit and them move up with multiple larger bits to get where you need to be.
Drill and turn with good ventilation, depending on what kind of stone or mineral, you could be breathing some dangerous dust.
__________________
Often wrong, never in doubt.
Chasper is offline   Reply With Quote Top
Old 01-30-2019, 11:14 AM   #3 (permalink)
Photos: 0
Default
Excellent info Chasper.
My question to Teacher is --
is the blank a stone like sandstone, marble, etc or
is it a Tru-Stone blank.
rholiday is offline   Reply With Quote Top
Advertisement
Old 01-31-2019, 10:31 AM   #4 (permalink)
Photos: 0
Default
Thanks for the info guys, did some you-tube viewing and also called the store where my son bought the piece. They say it was Young-stone(sp), similar to Tru-stone, a mixture of ore & resin. So will give it a go after this weekend. Too many irons in the fire and too cold work in shop. Will post a pic when I get it done.
Old 01-31-2019, 04:00 PM   #5 (permalink)
Photos: 0
Default
Yun-Stone, it's similar to tru-stone. Go slow when drilling, you don't want to build up too much heat. Some colors may be harder than others. Sharp tools, light passes and you'll be good to go!
__________________
I firmly believe that any mans finest hour, the greatest fulfillment of all that he holds dear, is that moment when he has worked his heart out in a good cause and lies exhausted on the field of battle victorious.
- Vince Lombardi
epigolucky is offline   Reply With Quote Top
Old 01-31-2019, 05:32 PM   #6 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Cut your blank long and do not drill all the way through. You can cut the end to open the hole. This will help prevent fractures or breaking out the exit end while drilling.
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
