I want to apply one stamp to a white tube. It is not self adhesive. Should I just moisten it and stick it on, or use mod podge or white glue or whatever?
CA works nicely but don't touch the stamp surface with CA on your finger. Mod Podge will work but let it dry for a couple of days. Actually, allow what ever glue you choose to dry for a day or two. The stamp adhesive should also work.
Do you plan to cast the tube or just build up a thick layer of CA?
