joeatact
I have been tiring different ways of stabilizing wood using the vacuum jar method. Here is what I found using poly http://tinyurl.com/c3hub
I have tried using Minwax Wood Hardener but not with the best results found it wasn't hard enough. This method works but darkens the wood quite a bit. Is there another substance (poly brand) that may not darken the wood as much?
Joe
http://www.joespens.com
Joe
