Squaring a Jr.Gent Blank
mick
Decatur AL, USA
Ok somebody help me. How do I square this Jr. Gent blank with a big old gaping hole in each end?....lol are there adapters out there for the 7mm barrel trimmer I have? Or do I just turn one on lets say.........a lathe.....lol. Maybe I just answered my on question!
Thanks guys!
JimGo
North Wales, PA
yup, you did. Twice, actually. Woodcraft sells some adaptors, but most people have turned their own. I got some Corian for just that purpose.
Oh, and PSI sells a whole kit of different sizes.
Good luck!
woodscavenger
Boise, ID, USA.
A disk sander can bite you in the butt unless you make a great jig that uses the brass tube as a guide but you would need an adapter for that as well. The easiest thing to do in my opinion is to use some spare 7mm tubes or salvage a set slimline blanks that didn't quite look as good as expected and turn one of them to fit the I.D. of the tube. It does not have to be perfect, just good enough to give yourself some decent alignment.
penhead
Local Chapter Leader
Chesapeake, Virginia, USA.
Sometimes a bite in the butt isn't a bad thing [:D][}:)][:D]
Originally posted by woodscavenger
<br />A disk sander can bite you in the butt unless you make a great jig that uses the brass tube as a guide but you would need an adapter for that as well. The easiest thing to do in my opinion is to use some spare 7mm tubes or salvage a set slimline blanks that didn't quite look as good as expected and turn one of them to fit the I.D. of the tube. It does not have to be perfect, just good enough to give yourself some decent alignment.
wayneis
Okemos, Michigan, USA.
The only thing that I have used for squaring blanks for the last six or eight months is a disk sander. I fand it much more acurite and pretty to do. I don't have to mess around trying to sharpen any barrell trimers, just made a few bushings that fit inside the different tubes and go for it. Oh ya, I cheated and bought a jig from PSI instead of making my own but hell I'd rather make pens, what can I say.
Wayne
Gary
Texas, USA.
I second what Wayne said. I use nothing but a disc sander. I made a jig using an old mandrel then a few adapter sleeves. It works much better for me than fussing around with barrel trimmers/mills.
