Splicing Woods
Lazarus812
Columbia, MD, USA.
I am new to penturning, but ready to try splice different woods together. I would be grateful for any advice on glues to use or techniques that will not show the glue seam once the pen is turned.
alamocdc
San Antonio, Texas, USA.
First, welcome to the group, Mickey! I use Titebond, but any wood glue should do. The trick to invisible glue seams is tight joints and you get those by jointing your edges, using a good saw blade, using a thickness sander, or any combination of these.
knottyharry
Wilkes-Barre, PA, USA.
Hi Mickey,
I use a mitre saw for my joints, then sand them with some real fine sandpaper, on a piece of glass.
I use gel type CA glue. But as long as you use a good glue that is the main thing.
I also use a piece of angle iron with a piece of waxed paper in it to assemble the pieces. The glue won't stick so bad to the waxed paper. What does stick comes off pretty easy.
Harry
