From what I have read in this thread it is evident that good folks here are experiencing what I have seen happen all to often ... that is, many are now so sensitized that they have had to either quit all together or to take extra precautions to prevent out breaks.
THAT in a nut shell is the reason so many of us MUST take these precautions early on from the very beginning. I was a fraud investigator for several major health insurance companies for many years. In my experiences I learned right away that IF one is prone to any form of allergies, then that individual must take extra precautions right from the beginning if they want to avoid long term complications later on.
I have always "preached" that dust collection is mandatory. One just can't seem to have to much dust collection available. I have found over the years that it is best to collect dust and debris immediately at the tool creating the offending material.
I have a LocLine system mounted to my banjo that is adjustable and moved along the wood being worked as I move my cutting tool or the banjo. I collect the majority of debris as it comes off the cutting tool and right at the cutting edge. It takes a bit of getting used to, but in the long run the extra effort is time VERY well spent.
I also have a four inch collection device of my own making that can be adjusted to assist the LocLine. This fits in the ways of the lathe and is vacuumed by the 4" main dust collection device. I have a shop vac attached to the LocLine system to vacuum the cutting dust and much of the shavings. The larger debris is either collected by the 4" system or simply falls to the shop floor for later collection and cleanup.
Whatever you decide to do, collect as much dust, etc. at the time of cutting and ALWAYS wear a sealed face shield. A smock with high neck protection and long sleeves is also a great addition. Just do everything you can possibly do to avoid bodily contact with the dust and such.
Like Dario has said above he has quit most of what he loved to do due to the fact that over time he became sensitized to some of the wood he was working with. It is possible that IF you do not have symptoms right now, that in time you too can become sensitized to the point that you can't even touch some of your wood without having a major reaction that takes many days to go away.
Your health depends on what you do now and will you will benefit from all the early precautions you can take now. It is also far cheaper to spend a bit of money on early precautions than to spend thousands more in medical bills later on, not to mention all the time lost due to the problems you are experiencing.
