Randy_
I am just getting ready to do my first snakewood pen. Was reading, last night, a piece on the wood and there was a comment about it not being very suitable for veneer as it tended to have a lot of cracks indigenous to the wood.
How prophetic............
I cut a blank in half several days ago and trimmed the corners so it had an octagonal cross-section. Today, I was marking the ends of the blank in preparation for drilling and was using one of those little high intensity lamps for illumination. While manipulating the blank, I noticed a peculiar glint of light coming from one surface so I got out my loupe for a closer look and surprise, surprise......I was looking at a crack in the wood!!!
I had looked that piece of wood over, carefully, several times under "normal" illumination and never noticed a thing. Under any other circumstances, I would have drilled the blank and not discovered that crack until after drilling or turning or maybe not at all. Somewhere down the line the crack would have been detected and an assumption made that something in the crafting process (heat?) was the cause of the crack......when, in fact, the crack had been in the wood from the get-go. (Note: This is wood that had been sitting in a shop for several years and should have been very stable.)
I wonder how many other cracked snakewood blanks had existing defects that were later attributed to the crafting process??
I was going to use this blank for a Sierra Click kit; but the location of the crack is such that it will intersect the hole for the Sierra tube. I'll have to look around at my stock of kits and see if I can find one with a smaller tube that might work or maybe I will just break the blank apart at the crack and glue it back together and use it for a personal pen?? :frown:
