its_virgil
Here is a picture my latest snak skin casting. Comments welcome.
Do a good turn daily!
Don
Don
Originally posted by Charles
<br />Looks Really nice. Is that just clear casting resin? With a mold that size how long did it take to cure?
Originally posted by Deere41h
<br />Don...Did you use corks to keep the PR out of the tubes? Is that what I see? Did it work under pressure and were you able to pull the corks out or did you cut them off and drive them out.
Originally posted by myname1960
<br />Did you use a pressure pot?
Which pens are these casting going to be used for?
When preparing the blanks for the skins is there a certain diameter under the finished pen diameter that should be held so the skins wont be turned away or cut into when finishing them?
Originally posted by Darley
<br />Really good Don, I see that you choosethe 40psi I leave mine for 10 minutes and woork well, but now run out of tube and Barons, I turn the last one yesterday for my daughter Birthday next month, tell me how many bottle of wine do you have to drink for all those pens[][]
<br />Doing some searching on the sites that sell the blanks i found 2 that carried snakeskin blanks.
One was the arizonasilhouette site which had sells the rattlesnake blanks for at least 14 different types of pens. El Grande and slimlines included.
Another site was the Glimmersnmore site. They have 5 different type of skins for 5 different styles of pens. They say that the rattlesnake skins doesnt work well for the slimlines due to their "texture".
Well at least you can make them or have them made for many differnt type of pens so we arent limited to one or 2 pen styles.
I am now waiting for someone to try to make snakeskin bottlestoppers. It would probably go something like this:
1)Turn the stopper undersize.
2)Glue a skin to some pantyhose making sure its very wet.
3)Before the glue totally sets you stretch the snakeskin laced pantyhose over the stopper blank.
4)When the glue has totally set you place the stopper in some clear casting resin.
5)Place the stopper in a pressure pot and follow your usual directions.
6)After the resin hardens you begin the finish turning process.
7)Sand and polish the bottlestopper to your liking.
There you go a snakeskin bottlestopper.
Maybe i should patent that method before someone else does []
On a serious note thanks for the info.
Chris
<br />
I was hoping to see an article on how the process of actually preparing the skins from the start to the finished product. That could include measuring the skins for the blanks, glueing them on and then after the casts are finished the cutting and sanding of the blanks and any other pointers the author had. Again i do thank you for pointing out the embedding article.
Chris
Originally posted by its_virgil
<br />I really like what we are onto with this pressure thing. I hope your pot arrives soon. Don't think Anthony has received it yet from HF.
Don
