JimGo
For those doing pressure casting, are you reducing the amount of catalyst compared to if you were casting without pressure? I tried casting snake skins this weekend and learned a few things:
1) Cocobolo does not make good stand-off material. It will bleed into the PR like crazy! Though, interestingly enough, the PR won't bond to the wood itself.
2) Harkening back to chem class in high school, the old PV=NRT equation (can't remember whose law that is) says that as you increase the pressure, the temperature will go up. Well, apparently the temperature increased SIGNIFICANTLY; my casting actually CRACKED. Granted, it was 90+ degrees outside, but there was a big crack in the PR, which was disappointing.
3) Heat sufficient to cause PR to crack while curing will also cause snakeskin to either shrink or simply dissolve. I had a LOT of air bubbles around the skins themselves, but from what I could see though the PR, the skin had actually either turned transparent, or dissolved, or something, out near the ends.
My guess is that I used too much catalyst for casting under pressure, and the catalyst made everything hotter (there's that chem law again). But I'd be curious to get feedback from you and others. I have some leaks in my system, and was thus only able to pressurize the pot to about 20-25 PSI, but since that's the same pressure Don Ward said he uses, that should have been OK.
Thoughts/suggestions?
