Smell from acrylic
Katsin
Vernon, NJ
If you get into casting your own blanks you can add scents to them though you need to take care of the impact of the scent material on the mix.
I never really notice much of a smell from my acrylic turned items.
hazmat74
Harrisburg, Pennsylvania, USA
If you're smelling acrylic after you've turned and finished it, there's something wrong. I know it has an odor when hot from being worked, but you shouldn't notice anything wafting off of it after that point.
1080Wayne
Brownfield, Alberta, Canada.
Are you sure that is acrylic ? They may have a slight vinegary odour immediately after turning , but to my nose at least , it is gone within a few minutes . Polyester odours may linger longer , perhaps a day .
Jim Burr
Banned
Reno, Nv
Is it from the blanks or you from being in the shop to long :biggrin::wink:? The smell usually sticks around from the heat generated from turning and sanding...then of course your choice of finish. Where do you get your blanks and are they just acrylic or something else?
