joeatact
Here is how I cut and turn small limbs:
This limb is about the size half of a slim line is in size. So with two you can make one pen.
Cut each piece about 1" thick. Then trim off the excess and drill your 7mm hole through the
center as usual. Glue in your tubes. Make sure you get good coverage and allow a good
ding time. Cross grain is harder so make sure your tools are sharp and go slowly!
If you click on the pen in the center you will see a picture of what the pen looks like
turned with grain and across the grain. You can find hidden pictures in small wood. Be
Careful cutting round and small pieces of wood.
Here is a link with pictures of the pens and results.
http://tinyurl.com/by3n7
