Dan_F
I got the 27/64" Norseman Drill bit for Sierra's from Arizona Silhouette, but find that the tubes don't fit near as well as tubes for the "O" bit. I tried one of my own 27/64 bits with the same results---not good. Is there perhaps a metric size which works better, or do you just live with the slop?
The tube actually measures13/32" o.d.- I tried a 13/32" bit, but the fit is too close to go in. I've read that the Harbor Freight bits tend to make a slightly larger hole than some others, would it be worth a try to use a HF 23/32, and see if it's off just enough to make it work?
Dan
Dan
