I built a slimline tonight and encountered a totally new problem.
When i installed the refill, it would only partly extend. I thought it was the transmission, so i removed that trans, and got a new one. Before i installed the new one, I checked it to make sure it worked properly and it worked fine. Then i put it in and had the same exact problem? What might the problem be? I havent taken it apart again to check it out, because i got frustrated. Before i tear it up, I thought i would seek guidance!!
Thanks, Ron
Thanks, Ron
