Slimline Pro
GBusardo
Beachwood, NJ, USA.
Hi all,
I bought four kits Slimline Pro Click kits from PSI a few months ago. Turned and assembled the first one and didn't like the way it clicked. Seemed loud and real cheap. So I did another. Same thing. I got an order for an assortment of 5 pens from a co worker. I decided to include one of the slimline pro's in the package after looking at the original pens and decided that while the click isnt so hot, the pens look sharp. I turned one and assembled and the click didnt work. It kept getting jammed on the retraction. I took apart as much of the pen as I could and didn't see or feel anyhting that could make it bind. Re-assembled and got the same thing. I turned and assemebled my last one (and I do mean last one) and the click assembley worked fine, but was still loud and cheap sounding. Does anyone know if this is typical of the click pens? Or maybe its just the kits from PSI. When I originally looked at the kit some months back, the plastic transmission did not impress me. Are there any better kits out there? As I remember, the PSI kits were not inexpensive.
Gary
Cam
Port Mellon, Britsh Columbia, Canada.
I did a couple of Craft Supply click pens that didn't work for me. Sent the assembled pens back to CSU and they determined that my tubes were to long. I didn't trim right down to the brass. Tube length is critical in the CSU kits. Since then no problems.
Cam
vick
Gilbert, AZ, USA.
The clickers on my CSU click pens worked great, I had problems with the clips bending way to easily though so I stopped making them.
dubdrvrkev
Gilbert, AZ, USA.
I think that is why these kits aren't more popular. Seems that the transmissions were not of the quality for a $20+ pen. Is it CSUSA that advertises the "new and improved" click mechanisms?
I have had a few people ask for click pens but I haven't made any due to the bad rap they have.
jkoehler
Mount Forest, Ontario, Canada.
I have made some of the Slimline Pro sets and I have had similar challenges with some of them.
I have also made the Power Pen and Pencil from PSI. i have had good luck with these. Also, I use the Power set everyday and have no problems with them.
Jeff
john46
Gulf Breeze, FL, USA.
Has anyone done the Berea Hardwoods "new and inproved clicker",
BHW-410? It has a different clicker system. So far I have found
it to work very good.
GBusardo
Beachwood, NJ, USA.
Thanks everyone, I would love to try the CS click pens, but if I have to buy new bushings too, I dont think so. Maybe simpler is better [:)]
Oakville, ON, Canada.
Originally posted by john46
<br />Has anyone done the Berea Hardwoods "new and inproved clicker", BHW-410?
I've done about a dozen or so of them without problems. They seem to be working OK after ~4 months. I don't know whether the 5A bushings will work for any other kit.
Be careful when truing the blanks not to shorten the tubes. If you do you will have problems retracting and/or extending the refill. DAMHIKT [:D]
Brent
Illinois, USA.
BB sells some of the newer ones that suppose to have a no jam mech. I made some for christmas presents for some of my family members. the TWO that the wife grabbed onto seem to work fine. But she still has her slimline pro that I made her last year and have had no problems with it,but it does click loud. I've also noticed that you need to play with the refill a little to get it to go all the way up in the pen before putting on the nib. If you just drop in the refill and force the nib on it will cause you problems. I think the new one's that BB sells are better made.
