GABJR
I attempted to assemble some slimline pencil kits last night.
I am not happy with the results. only 1 out of 3 would work.
on the one that does work, the mechanism seems to protrude to far out of the tip. the other 2 had to be forced through to screw the tip on & then would not work when the cap was pushed.the cap seem to be hung up. Should the mechanism slide easily through ? I am going to disassemble & start over. Do i need miil or clean up the tube ends before assembly ? all suggestion & tips will be appreciated
