Slimline finial fit problem - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 12-13-2018, 04:00 PM   #1 (permalink)
Photos: 0
Default Slimline finial fit problem
Haven't done a slimline in a very long time. Recently found that the finial appears to be too big for the standard clip - same problem with a music themed clip I tried.
Drilling out the hole in the clip is doable but has anyone else had to do this?
MPVic is offline   Reply With Quote Top
Old 12-13-2018, 05:00 PM   #2 (permalink)
BURLMAN's Avatar
Photos: 10
Default
I have had that problem with slims with the rhodium plating. My fix was to drill out the small end of an old cigar center bushing so that it fits over the part of the finial that is pressed into the tube. Put the clip on the finial as far as you can and then use the bushing with your pen press to press it home. Had to do that this morning, as a matter of fact.
BURLMAN is offline   Reply With Quote Top
Old 12-13-2018, 06:39 PM   #3 (permalink)
Photos: 0
Default
Thanks very much - that sounds like a much safer method.
Advertisement
Old 12-13-2018, 06:57 PM   #4 (permalink)
KLJ
Photos: 32
Default
I just use a file on them it didn't take much effort.
KLJ is offline   Reply With Quote Top
Old 12-13-2018, 10:01 PM   #5 (permalink)
BURLMAN's Avatar
Photos: 10
Default
Quote:
Done that as well. However, too time consuming. When this happens, the problem is solved inside a minute.
Old 12-13-2018, 11:46 PM   #6 (permalink)
tomas's Avatar
Photos: 0
Default
I just carefully press it on with my pen press. I also use a touch of LockTite blue and these finials.
Tomas
tomas is offline   Reply With Quote Top
Old 12-14-2018, 06:23 AM   #7 (permalink)
Photos: 0
Default
Thank you all for your input - much appreciated.
MERRY CHRISTMAS!!
Old 12-14-2018, 07:41 AM   #8 (permalink)
Local Chapter Manager
ed4copies's Avatar
Photos: 27
Default
I kept a Dremel next to my pen press (actually an arbor press). A few passes on the inside of the ring, top fits great.
Yes, loctite is a good idea on all clips--as they wear they are prone to spinning.
__________________
Ed Brown
ed4copies is offline   Reply With Quote Top
Old 12-14-2018, 08:20 AM   #9 (permalink)
Photos: 0
Default
I use a piece of 600 grit sand paper wrapped around a transfer punch and sandy lightly and I always use "blue" Loctite on all parts (finale, clips and nibs) during the assembly regardless of the kit.
Wade
__________________
Wade (Zig)
zig613 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
