Slimline bushings - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 11-11-2018, 08:32 PM   #1 (permalink)
Photos: 0
Default Slimline bushings
Hello all. I'm a rookie pen turner who has just taken delivery of a PSI lathe and "advanced starter kit". I set everything up this afternoon and realized the kit did not include slimline bushings. Instead of waiting for Pen State to send a set I could go to the local Woodcraft store in Tucson or take a road trip to Phoenix to the Rockler store and pick up a set. My question is are Rockler and/or Woodcraft bushings compatible with Pen State slimline kits?
RussBerg is offline   Reply With Quote Top
Old 11-11-2018, 08:40 PM   #2 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Yes. Slimline bushings should interchange between brands.
HINT: get a good set of calipers from Harbor Freight - get the metal ones, not the plastic ones. Turn by measuring rather than by the bushings. Every time your chisel touches the spinning bushings, it knocks a few .003 thicknesses off of the bushing. Before long, if you judge the blank by the bushing, it will not be the proper size.
Calipers on sale at HF should be about $10.00.
OH, WELCOME Russ!
__________________
Hank Lee
Good is the enemy of Best
leehljp is offline   Reply With Quote Top
Old 11-11-2018, 08:41 PM   #3 (permalink)
TonyL's Avatar
Photos: 6
Default
They should be compatible enough to where you can use micrometer to achieve the final dimensions. You can also consult the IAP app. WCFT is the acronym for Woodcraft.
Home Depot sells a General Brand micrometer (about $30) that I found to work well enough to make a obtain the correct hardware dimensions.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Advertisement
Old 11-12-2018, 08:59 AM   #4 (permalink)
Photos: 1
Default
The turning kit I got from PSI included 5 7mm bushings. That's all you'll need to turn Slimline pens. Use a caliper to check but you should be good to go.
wolf creek knives is offline   Reply With Quote Top
Old 11-12-2018, 12:24 PM   #5 (permalink)
Woodchipper's Avatar
Photos: 1
Default
Welcome to the Wonder World of Penmaking. We would like to see some photos of your pens. There are lots of great folks here, willing to share their expertise and experience.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 11-12-2018, 01:33 PM   #6 (permalink)
Photos: 0
Default
Go buy the bushings and use them while you learn pen turning, as you get better with everything else such as tool technique, finishes and sharpening the tools you can decide whether to turn without the bushings.
wouldentu2? is offline   Reply With Quote Top
Old 11-12-2018, 01:47 PM   #7 (permalink)
Chief TomaToe's Avatar
Photos: 0
Default
Hello Russ, I'm a rookie at wood turning as well. I had the same dilemma as you after I bought the whole PSI starter kit. Like you, I thought that the kit was missing the slimline bushings, but if the mandrel came with the kit, the spacer bushings that come on the mandrel actually work as bushings for the slimline kits. I realized this after I bought "slimline" bushings elsewhere and realized when I put them on the mandrel they were the same exact thing! I hope this helps.
Chief TomaToe is online now   Reply With Quote Top
Old 11-12-2018, 02:20 PM   #8 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Since you are new: A bad news - good news about slimlines
Slimlines are generally more difficult to bring to size and get a great fit for those just starting out. However, once you get the hang of a slimline and make a few slimlines in the SLIM format - where they are straight from the nib to the center band to the clip end, - you will have a great handle on the basics and can handle most other pen styles and brands without a problem.
And the good news, is that in the learning stage, the slimlines are the cheapest ones on which to experiment and learn.
__________________
Hank Lee
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
