Firefyter-emt
Thought ya'all might like to see what I did tonight. I have converted to turning between centers for pretty much all my pens. However, this did not work with slimlines. Last night I saved a scrap of that crib dam wood that was only big enough for "almost" a slimline. So I added some AB-wood and figured I would give one of those custom slimlines a try.
I am so cheap I took a reject slimline, pulled off the cap and removed the refill. I then gently put the nib into the live center and the dead center into the transmission. I used a little masking tape to hold the pen to the dead center and turned off the wood. This gave me the bottom end of the pen. I then turned off the wood from the cap after popping out the clip.
But, back on topic... when I glued the blank I used some 1/4" rod and with the top tube glued in place the lower part presses in just fine, but if I add a spare tube and try to put it on my mandrel it binds up a bit.
Hmmm... What to do??? Well, with a metal lathe you can open up a lot of ideas! I took some scrap stock and made myself a pair of custom "between center" slimline bushings. I love using my homemade ones over the normal bushings because I drill a 60 degree hold to turn it on the metal lathe, which becomes my hole for the wood lathe as well. These holes are much better than holding the standard bushings.
Here are some photos, pay no mind to the length of the bushings; I did not care if they were the same length as long as the diameter was correct.
I am "kinda" kicking myself in the rear for not making this more like a teachers pen design with the black wood on the pull out part, but live and learn, eh?
I would show a photo one, but I have 2 coats of CA on it and the last coat I left my light over the blank on and it looks like a fly strip right now!!
