Randy_
There is a thread going over on the Yahoo site about Berea 2B bushings that are not sized properly. This is sort of an interesting bushing set because it is used in three different kits. The original question involved the Streamline Americans kit; but the bushings are also used for the Series 2000 Flat Top American Screw Caps and the Flat Top American Snap Caps. Since I had a set of those bushings that I had not yet tried out, I got out my trusty vernier caliper and took a few measure measurements. Sure enough, my bushings had the same defect. The barrel bushings were about 0.008" oversized and the cap bushings were 0.004" undersized. And with my set there was the additional problem that one of the bushings had a seriously undersized diameter for the section that fits inside the tube. It measured 0.013" less than the diameter on the other three bushings???
For anyone who has an unused set of bushings laying around, you might want to measure them up to be sure they are OK.
Just for comparison, these are the measurements of my bushings:
Cap Bushings
0.340/0.488
0.3525/0.4875
Tenon Bushing
0.488
Cap hardware measured 0.492
Barrel Bushings
0.353/0.4515
0.353/0.452
Barrel hardware measures 0.444
Tube IDs measure 0.357"
Cap Bushings
0.340/0.488
0.3525/0.4875
Tenon Bushing
0.488
Barrel Bushings
0.353/0.4515
0.353/0.452
