Simple (probably dumb) question re: Cigars
warreng8170
Denver, NC
I bought a couple of cigar kits along with the bushings and bit in the last CSUSA group buy. I was looking to buy some more, but was thinking of getting them at Arizona Silhouette along with a few other things. My question is: Do all cigar kits, regardless of manufacturer, use the same size bushings or do I need to order another set of bushings from AS to go along with their kits?
Thanks,
Warren
ed4copies
Local Chapter Manager
Racine, WI, USA.
I think it depends on how perfectionist you are about your pens.
I have used everyone's kits and everyone's bushings. Once in a while, they don't fit exactly right - I only make one kit, then assemble for just this reason. When they are not PERFECT, I will use a caliper to "fine tune" the next ones.
They are always "usable" if you're not the "perfectionist" type (this assumes you put the bushings in the correct order[:0][:0][:0][:0][:0]
pipeyeti
Chicago, illinois.
Ed! your not a perfectionist!:D
I have alsofoundthat the cigar bushings and kits seem to be interchangable
ed4copies
Racine, WI, USA.
No, we stopped Mudder's BICkering!
And, I dispose of imperfect pens that I SEE. My eyesight is known to be VERY imperfect.
AND, there's the issue of WHAT cracked on the WAY TO THE SHOW!!! Had THAT conversation with a customer once. He was HOLDING one of my buffalo horn pens, he could FEEL the crack as I told him it was fine (this was BEFORE I knew it was capable of cracking). When you sell pens long enough, you can make a real jackass out of yourself at least a couple times!!!
Hope this will help you avoid the same mistakes. FEEL the pen, if they tell you it SEEMS cracked!!!![:0][:0][:0]
M
Mudder
Guest
Folks,
This has got to be one of the biggest understatements that I have ever read.
This is NOT a BICker Mr. Brown for every once in a while there is a moment of truth, or a Freudian slip. [:0]
We've just witnessed one of those moments. [8D]
redfishsc
North Charleston , SC
Lord have mercy, boys, now y'all don't get your panties all in a wad!
Now, to answer the original question, I've made cigars from about everyone that sells them and I have bushings from most every one, I can't tell one from the other and they all seem to work just fine.
I do, however, have a preference for CSA's bushings, the nickel plating on them seems to help them last longer, but it may be my imagination.
stevers
Bullhead City, Az., USA.
I personally don't trust the bushings for final fit on most pens. Maybe slims and some euro's. I use a caliper on most to make sure they are right on.
As far as fit to mandrel or bushings to tubes, I have noticed little or no diff between.
