Silver, brass inlay question
justaccord
Colorado, USA.
Sorry if this is a dumb question, but I'm a real novice.
I want to create a groove with small parting tool and inlay brass or silver. If you inlay with (square) wire, how do you make the seam invisible where the circle completes?
Dave
jdmyers4
14127 129th Ave NE; Kirkland, WA 98034
I wouldn't use wire if what you're doing is trying to make a small cirle of brass/silver on a pen. I would cut the blank in half at the place where you want the brass/silver, and then glue a piece of 3/4" x 3/4" of brass/silver sheet between the two pieces of wood.
Silver sheet would be expensive. You might consider the less costly nickel-silver - which contains no silver, but has a silver-like shine when polished.
I'm considering using brass and nickel-silver for some upcoming segmented pens I'm going to make.
John
