Sierra vs Wallstreet II
Rick1708
These pens look very similar to me. Are they the same pen using different names? I have some bushings for a Wallstreet II and want to make an Elegant Sierra and am trying to find out if I need new bushings or not.
Thanks.
KenV
Juneau, Alaska.
Use your calipers/micrometer to control the ends to match the fittings and any differences in outside diameter are avoided. Firm fit inside the tubes is needed, but use measurements to make the match.
Rick1708
Good point, I'll double check the tube size and use calipers when close to finish.
Russianwolf
Martinsburg, WV, USA.
What Stan said.
Other names that work with those bushings are Pacifica (from Woodpenpro), Apprentice Classica (from CSUSA) and Gatsby (from PSI).
I use the Two-tone Pacificas myself since they are less expensive and look much nicer.
heinedan
Oak Lawn, IL, USA.
Hello,
I have to disagree. Woodcraft's bushings are garbage. When I used their bushings for the circuit board Wall Street, the pen turned out out od round. Ditto for Navigators and Sedonas. My recomendation would be to use a micrometer to measure, then if they match use your sierra bushings, otherwise turn without bushings and measure regularily.
Dan
sbell111
Franklin, TN
Hello,
Dan
I'm having a little trouble envisioning how a bushing could result in an out of round pen. I'm probably just not thinking right.
leehljp
Member Liaison
Tunica, Mississippi,
I had one Sierra bushing in which the hole was visibly drilled off center. I have had 2 others that were drilled off center and not noticeable until it was on the lathe. Then, by measuring with calipers, it was confirmed and enough for me to throw them away.
However - getting technical about the term OOR - Out Of Round, Non-concentric, Off Center, Elliptical are often expressed under the single name of OOR but technically are different.
waterloo, ny, USA.
I used to get all of my bushings and kits from woodcraft, until I was convinced that the bushings were not always accurate ( this was by an employee from there) But, Thanks to the bushings not beeing center, I got to get a full size lathe rther than the bench top. Something good can come out of woodcraft bushings.
