Sierra Transmisson Failure
intillzah
Larned, Kansas, USA.
I had the transmission on my daily sierra go out. Is it common for this to happen? Is this an issue I need to address and keep some spares on hand?
bitshird
Adamsville, TN, USA.
Did the Tranny quit working, or just come unscrewed and go up into the tube and can't connect, (which is a very common problem with Sierras,) That's why I stopped making them.
Whaler
Sequim, WA, USA.
I don't know if all Sierras use the same transmission or not but I have heard that there are several manufacturers that use the Sierra name. I make only Elegant Sierras and have sold a bundle over the past 3 years and have never had a problem.
intillzah
Nope, it tranny quit... It may be my fault it failed, I'm a figitier and I play with it a lot thru the day..
Whaler
Sequim, WA, USA.
A drop of blue Loctite on the top of the tranny solves that problem.
maxwell_smart007
Lead Moderator
Staff member
middle of nowhere in the great, white North
But makes it more difficult to change the refill...
Whaler
Sequim, WA, USA.
You simply screw it apart and the transmission stays in place, actually easier than pulling it apart and then unscrewing the transmission.
