MrKugelschreiber
I went into a Rockler woodworking store today and they offer a Manhatten style pen. This "appears" to be the same as the Sierra. Does anyone know if the bushings and so on are the same? Thanks
Yes, tube & bushings are the same.
Rockler used to sell the Berea Sierra under that name, but changed to the Manhattan a few years ago. I don't know if it is still the Sierra with a different name or if they changed the name because they are sourcing it from a different supplier, but the specs are the same.
Yes, and the Wall Street III is equivalent to the Sierra Vista.
I recently turned a Wallstreet III, and the Woodcraft instructions say that the bushings are the same diameter. But the Berea instructions for the Sierra Vista say that the bushings are different diameters. I just measured my WS III bushings, and one is .525", the other is .524".
http://www2.woodcraft.com/PDF/77C67 WallStreet III Pen Kit Instructions.pdf
http://www.bereahardwoods.com/pdf/SierraVistaPen.pdf
Thanks for pointing this out, Jim.
Looks like we need to correct that info in the bushing & tubes charts and app.
Edgar
Edgar
Isn't that probably within the manufacturing tolerances or the result of sanding or touching with a tool?
I think the real issue is that the Sierra Vista uses 2 different sized bushings - .551 & .523 while the WSIII uses two identical bushings, .524 & .524 -- we have the WSIII listed the same as the SV in the charts & app, which is apparently incorrect.
