I had asked the same basic question a week or three ago. Here is a link that was supplied in my thread.
http://www.penturners.org/forum/topic.asp?TOPIC_ID=32625&SearchTerms=sierra
It can be done, but I have found that it is a bit of a pain in the butt. I did the lower section last night. It was a challenge, for me at least. I used long punches to take it apart. There is a metal ring inside the plastic part that got ruined in my case. But I didn't need it the way I put it together.
Someone mentioned that it needed to be step drilled. I didn't do it that way. I just drilled a hole on one end for the connector and a hole for the nib on the other end. That hole I drilled all the way through and used it for the center for the larger hole.
I also made some bushings from corian for this part. The ends wind up being very thin. I don't have digital calipers, but guessing, maybe 1/32 thick on one end and thinner on the other. If I can finish the pen today I'll be posting a picture in SOYP.
Hope this helps some
