Randy_
The Sierra Button Click kit has that annoying little metal extension so the pen can be used with either a Parker® brand ballpoint refill or a uni-ball® refill. The little extension is easy to loose and actually won't even work with the Parker® made refills so some folks have opted to throw away the extensions and shorten the barrels somewhat so the pen can be used with the Parker® refill without need of the extension.
I would like to hear from some folks who have actually made up shortened pens and find out what tube lengths they are using.
There is information on the AS web site that says the tube should be 1.882" long; but calculating from measurements of the actual pen components, it looks like the tube needs to be closer to 1.918". That is nearly a full millimeter difference. Using these numbers, we are either going to end up with a pen where the refill sticks out too far or not far enough.
So all of you who have actually done this conversion, which is it??
Thanks.
Thanks.
