Shock Absorber pens squaring
WriteON
Florida & Pa
What are you using to square off the blanks. Is there a specific sleeve used over the barrel trimming shaft?
OK..I use the lathe also. My question is what size shaft is used with the squaring barrel...or is a sleeve used over a shaft?
Sleeves can be made to fit any tube. No need to get separate shafts for each tube size. Just glue a 7mm tube into a piece of wood or other material and turn it down so it just slips inside the tube of the kit being made. Although there are many many kits several kits use the same size tubes and you will soon have enough of these sleeves to work with the kits that you make. This picture may help.
Do a good turn daily!
Don
Don
That does help. You're quite creative. Thanks. Frank
By on the lathe I mean holding the rounded blank in a collet chuck and use a turning tool, no end mills or shafts at all! But the 7mm custom sleeves will work good too.
