I've had CA fail during drilling, so I'm pretty sure that it was because the heat generated by the drill bit was transferred to the metal, then to the CA, causing it to fail. Some have pre-drilled then glued in order to avoid that. Drilling with a smaller diameter bit and building up the the correct size (allowing time for any heat to dissipate) may work also.
