segmenting with brass
great12b4ever
Houston, Texas, USA.
I have a probably stupid question but here goes. I see a lot of people segment there wood with aluminum from coke cans. Does anyone use brass for segmenting? I have a fair amount of brass that is .002" and .003" in thickness that I think would be perfect for segmenting. Is there a reason NOT to use brass? I use a CA finish on my pens so it should be covered well to prevent discoloring.
Rob
LEAP
Old Orchard Beach, Maine
Hi Rob,
Ive got a roll of brass sheet .002" that I'm thinking of cutting into thin strips and curling up in a casting. I'm waiting for the powder dyes for the PR. let us know if you give it a try I'm curious to know what your experience will be.
leehljp
Member Liaison
Tunica, Mississippi,
I use brass quite often now and have been for about a year. If coated with CA as a part of the finish, there should be no tarnishing.
Here is the link to an experiment that I tried (and it worked very well) in which I wanted a larger slimline. I used 1mm thick brass sheeting as spacers.
http://www.penturners.org/oldalbums/leehljp/Slimline%20end.jpg
A pen with .5mm sheeting as a separator in the segments:
les-smith
Oklahoma
Dang Hank, That's a nice looking Sierra. I like the larger slimline idea. I'm going to give that a shot.
great12b4ever
OK, I will do some segmenting with my brass, and let y'all know how it comes out. If I can ever get my camera set-up finished, I will post some pictures.
Rob
leehljp
Member Liaison
Just a note to take small cuts and keep the chisels sharp. I have to do this a lot more often with the brass than with anything else.
great12b4ever
Thanks for the tip, Hank. I have the Tormek system, and will make doubly sure everything is scary sharp. I have found that keeping the chisels very sharp and honing often has allowed me to turn unstabilized burls and small segmented items without blowouts or ruining the blanks and glue-ups so far (knock on wood)
Rob
leehljp
Member Liaison
Originally posted by jdmyers4
<br />I've been wanting to use brass. Hank, do you use soft brass or half hard brass sheet?
John
I don't know the real difference. I think mine is the half hard because it is in sheets. The sheets here are available in approximately 4" X 12" and 12" X 12" sheets, in .1, .3, .5, 1.0mm, 1.5mm, 2.0mm.
I can get the same in aluminum also and a few of the thicknesses in copper.
leehljp
Member Liaison
Oh one other thing (Rick's post reminded me of it) - I do not segment all the pieces and then drill. Instead, I put the central portion on the tube, turn it until the center part is squared. Next, I take the tube off of the lathe; make sure succeeding pieces/segments are as square as I can possible make them. Then I add the brass and end piece with plenty of CA or epoxy. For me - I make sure that the end pieces are about 1/32 inch longer than the ends of the tubes, I quickly put a clamp on it and bring it up tight/snug and let it set for about an hour.
I have done several this way. It may not be the most convenient way but it is the only way my mind is working.
ON the BRASS: Since I drill the holes first, and if you choose to do it this way - here is a TIP: I place my sheet of brass on a piece of 1/2 plywood that is about an inch larger on each side than the brass sheet. I lay another piece of 3/8 or 1/2 in ply (approximately the same size as the other ply) on top of the brass and screw the two sheets (of ply) together around the edges, with a screw about every 3 inches. Next, I drill holes slowly on the drill press . This will hold the brass and make smooth cuts.
I drill about 20 or 30 holes at a time, space about an inch apart. Then I take the screws out and use some shears to cut out brass "washers". It doesn't have to be perfect, just enough to be a tad larger than the finished blank size. The brass might "curl' as you cut it but that can be flattened out between two boards with a hammer. The holes need to be fairly accurate; the outside does not, as it will be turned down.
I use a fast lathe speed and VERY slow/small cuts on the initial brass portion of the glued up segmented blank.
GaryMGg
McIntosh, Florida, USA.
Someone say Brass segmentation; this goes a step beyond segmentation -- hand-made inlay.
These are NOT MINE but are evidence that you can run the brass lengthwise and
not have a problem. Each of these is a true inlay. The brass does not go
all the way thru the blank. The inlays are parallel to one another thus the pattern
repeats all the way around the pens.
<br />
<br />
What that guy with the Jamaican accent used to say?:
Try making that out of a Cola nut. [:D][;)]
