segmented bullet pen
penmaker1967
biscoe nc
hi guys i was wanting to do a segmented bullet pen . has anyone done it before, any ideas on how to do this would be greatly appreciated .
pensmyth
Reynoldsburg, Ohio
Here's one I made from scraps of acrylic I had left over. Just CA'd them together drilled and turned as normal.
jskeen
Crosby, Texas, USA.
Is this something like what you had in mind? I had to dig way back for this one, it's from a while ago. Anyway, nowdays I would use a bullet for the nib and put the clip under the casing base on top instead of just sticking it on top, but the basic concept still holds. I still have this pen and still use it regularly.
BTW, that's a USAF expert marksman ribbon on top, over a section of purpleheart.
LeeR
Fort Collins, Colorado
Eric,
Your segmented bullet pens are really nice looking -- something for me to file away as a future project. I am not a big fan of the bullet pen kits, and I think the main reason is that I jsut do not liek the clips that are rifles, although they could be replaced.
Thanks for he inspiration to try a different approach to a bullet pen.
Ironically, I just bought the little mini saw you from Harbor Freight a few days ago, which you mentioned in one of your posts. I thought it would be a good tool for cutting brass tubing. I had gone to Harbor Freight to buy an arbor press, and noticed the mini saw on sale. BTW, for those that are not happy with their current method of assembling pens, an arbor press is a nice way to go. I added a small disc of UHMW (polyethylene) to the ram, and use UHMW for the base, although I need to fashion an additional base to accomodate long assemblies.
Pineville, Louisiana
This is one i did cuting using 11.5 degrees some coppper and some aluminum. Just glued it all together and turned.
