keithbyrd
I have done a fair number of segments and have only had one blow out. I also have never used epoxy. But being fearful I decided to use epoxy to make a couple of thin blue line pens. So I cut two African blackwood blanks and two Royal ebony blanks and blue plastic strips and epoxied them together. No problem until after I drilled them. Sharp bit, plenty of clean out, didn't get hot. But when all finished I simply picked them up, gave them a gentle twist and every one of them came apart.
Is it the epoxy? I used Stick fast 5 min high strength. Is there a problem with plastic and epoxy? I did lightly sand to scuff it up.
I am guessing I should have stuck with the CA.
Any experience out there that can help?
