So, I'm guessing I am the only one here to EVER have this happen... :tongue: but I had my first tube seize up on me during the glue up process. Everything seemed to be going as per normal. Drilled, reverse painted, overnight dry, and thick CA …but then out of nowhere it just locked up, almost instantly! It also seemed completely indifferent to me, because it didn't matter how much I begged, pleaded, pushed, pulled, screamed, or cursed. The tube was done, and stubbornly refused to budge.
Now if this were just any piece of wood, I'd still be irritated, but probably just say, "oh well" and toss it in the scrap bin. As you can see though, this is not just any piece of wood. This is one of Jeff Powell's beautiful Black Ash Burl blanks, so I am contemplating how best to attempt saving it.
As I see it, these are my options:
1) Do nothing and toss it in the scrap bin. (not really an option for a stubborn person like me)
2) I could do my absolute best to try to square up the face, cut off the remaining tube, and try to re-glue the 2nd half of the tube in the back side, so that the 2 ends meet together. (this seems a little far-fetched since it is highly unlikely that I could ever get the ends of the tube to match up close enough inside for the pen to actually work once it's done)
3) I could try to use a de-bonder to dissolve the CA enough to get the tube out. (but I assume the de-bonder will also eat away at the acrylic and ruin the blank)
4) I could try to drill it out. (but due to its composite nature, it seems likely that this would just cause the blank to explode)
Truthfully, I don't like ANY of these options, but since #1 is absolutely out of the question, I have to at least TRY something else. Anyone have any suggestions for a semi-noob to pen turning?
(on a side note, I have already ordered and will be transitioning to 15 min epoxy from now on)
