Seam Ripper Question - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 03-23-2019, 09:44 AM   #1 (permalink)
Photos: 0
Smile Seam Ripper Question
Hi all,
I have a request from a customer that would like a 90 degree pick, or awl type end, on one end of the seam ripper. She will use it for loom knitting. Looking at the stiletto end, I was wondering if the stiletto could be removed and a different end epoxied in. Any idea if this would work and how I would go about trying to remove the stiletto?
My other option is to turn a separate handle and epoxy in a 90 degree pick.
Thanks,
Jeff
__________________
Jeff Miller
www.MillerTurnings.com
MillerTurnings is offline   Reply With Quote Top
Old 03-23-2019, 10:10 AM   #2 (permalink)
Photos: 1
Default
PSI, and others, have kits you can buy that has the pick you're talking about. You don't glue the pick or ripper in, there's a small, very thin piece you slide into the tube that holds the end in place. The ends are intended to be pulled out, turned over and placed back into the tube so that the ripper/pick end is not exposed during use, only one side at a time is exposed. I hope this helps and I hope your customer enjoys what you put together.
wolf creek knives is offline   Reply With Quote Top
Old 03-26-2019, 12:50 PM   #3 (permalink)
Photos: 0
Default
Never tried to remove the stiletto end. Doesn't look like it would be easy to do.
Another option may be to turn a plug or dowel that would fit the one end of the seam ripper. Glue the plug in place and drill it for the 90 degree end that is requested and glue that into the hole.
Bob
rholiday is online now   Reply With Quote Top
Advertisement
Old 03-27-2019, 09:32 AM   #4 (permalink)
Photos: 1
Default
Maybe I misunderstood the question. I was thinking of something like this (Item #: PKSR4CH) from PSI. No glue needed and you can customize the ripper with different ends.
__________________
Not to know what happened before you were born is to remain forever a child- Cicero, 46 B.C.
Old 03-27-2019, 10:17 AM   #5 (permalink)
Photos: 4
Default
Quote:
I was wondering what you were referring to, was there a pick tool available? Maybe the confusion is the OP asked about a 90 degree pick or an awl. To me, the stiletto tip is pretty close to an awl, but Iím unaware of a pick.
So back to OP- I suppose the stiletto tip could be removed and a pick epoxied in, but not especially easy. I donít know what kind of pick a loom knitter needs, but could the stiletto tip be bent 90 degrees, maybe with a little blow torch help? If the pick tip is available separately, I too like the idea of turning a plug out of whatever the body of the seam ripper is made of (to keep that end reversible/interchangeable) or just make the body closed ended on one side, drill a hole through for the pick and epoxy the pick direct into the body.
__________________
"In theory, there's no difference between theory and practice. In practice, there is."-Yogi Berra
Shock me is online now   Reply With Quote Top
Old 03-27-2019, 04:08 PM   #6 (permalink)
Photos: 1
Default
In my thinking, I'm putting the pick and stiletto in the same category. Sorry for the confusion...for all of us.
__________________
Old 03-27-2019, 05:55 PM   #7 (permalink)
Photos: 0
Default
My original question could have been worded better. I make many seam rippers, but was looking for a way to unglue the stiletto end from the end cap and epoxy in a 90 degree pick. I have no idea what kind of glue was used or how to dissolve it. Giving my customer a seam ripper with a ripper end, stiletto, and a 90 degree pick would have been awesome. In the end, I just turned a long handle from an acrylic pen blank in her favorite color and drilled a tiny hole about 1 1/2 inches deep in one end. I bought a small pick set from Harbor Freight that had a 90 degree pick, cut off the handle from it, and epoxied it into the new handle. It turned out pretty nice, and the contours are similar to my seam rippers. My wife did me a favor and mailed it right out before I could get a picture of it. I know, no pictures - didn't happen, right? You all will just have to trust me....
Thanks to all for the input, and I apologize for any confusion.
__________________
Jeff Miller
Old 03-28-2019, 02:26 AM   #8 (permalink)
Photos: 0
Default
I kept thinking that you would try bending an existing stiletto. Did you try that or would it have been too short?
penicillin is online now   Reply With Quote Top
Old 03-28-2019, 04:24 AM   #9 (permalink)
Photos: 0
Default
It would have been too short for her purpose. I also doubt it would bend without heat, and I didn't want to either break it or discolor it. She received it in the mail last night and said it works perfectly and fits her hand nicely. I'm waiting to see if there is a need for more of these….friends don't let friends use standard store bought tools!
__________________
Jeff Miller
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
