Screwed up a triton convertible
Lenny
Searsport, Maine
Yes they certainly can be used ... the only thing is one of the tubes needs to be shortened slightly for the triton. Alternatively you can stretch the spring. I prefer the first choice myself. Let me go check my measurements on what the exact lenth should be.
Lenny
Searsport, Maine
The Triton tubes are 1 55/64 and 1 29/32
The Jr. Gent II tubes are 2 5/64 and 1 29/32
at least that's what my notes say. :wink::)
Check those with the ones you have and if something doesn't seem right let me know and I'll re-check some actual tubes.
Lenny
Searsport, Maine
Is it the barrel tube that needs shortened?
On the Jr. Gent II the larger diameter (upper) tube measures (corrected) 1 57/64 long
the lower barrel tube (smaller diameter) measures 2 3/32 long
The Triton upper tube (large diameter) measures exactly the same (1 57/64)... no trimming required .
The lower tube (smaller diameter) measures 1 55/64.
So trim the Jr. Gent II lower tube to 1 55/64 for the Triton.
PenMan1
Eatonton, Georgia
Or...... Leave the bottom barrel the same as a jr gent II and just use a longer spring. Either way will work. The difference in length is only 1/8th inch.
