sandking
I have a deer antler that I want to turn for my dad (it was his deer so there is some sentimental value). Being new to turning and pen turning, I cut the blank and drilled the 7mm hole for the slimline. One of the antlers came out too thin on the bottom, but I think I can work with it.
The problem is when I was reeming out the top the brass tube got chewed up.
Is there a way I can remove the brass tube? I used thick CA glue to set the brass.
